my mechanic replace on freeze plug behind the starter but i still have a small leak he says it is comeing from another plug that requires the trans to be dropped. If i get this done what else should i do at the same time? rear main? new trans mount? install new o2 sensors? please give me some ideas. thanks, ben
i'm sure the precision converter is great but are there other converters that wont break my bank?- by the way thns for the tip
make sure it isn't the coolant tube that runs under the manifold. Pull the alternator and check for sure.
