hello.....i have been having this problem with coolant level sensor showing low coolant indicator as i m pretty new to these cars and cant find fsm either so i need to know that wat could be wrong...sensor or wiring?...my coolant is full to specs but duno wats the problem....how many volts should be at sensor or resistance?
thanks mikeyB but isnt coolant temp sensor and coolant level sensors r different? i m talking about the one in coolant reservoir
Try cleaning the contacts on the sensor. When the coolant touches both contacts it makes a circuit. When the coolant is low it no longer makes the circuit turning on the light.
I cleaned it wit electrical cleaner but its still showing low coolant. How many ohms this sensor suppose to have wen working rite
