1 - 12 of 12 Posts
Ive been having a problem with keeping coolant in my car. Ill add some more coolant and in a couple of days the low coolant light will come on again. Ive checked for leaks on the outside of the engine and the readiator and havent found any leaks. I was just wondering if i was buring it all because of an internal leak or what else could be happening?
check your oil, if its milky you have problems
coolant loss
.ditto....... take a 20min run somewhere, park car,put card board under car, run for a fewmins in park to check for leaks. if none check in a few hrs the coolant has to go somewhere on the ground, or inthe motor.. if doing this at night......let car run open hood.. check in y smell anti freeze....have a flashlight handy to shine in motor and under neath could be a pinhole on 1 of ur coolant hoses.
this sounds like the notorious 3.8 :)
check all hoses (rad/ heater) check your passenger floor for water (heater core failure) check behind the w/p (also the weep hole), check behind the timing cover, make sure the radiator has no leaks. also smell the exhaust, and if it smells sweet then it's probably HGs.
This is the best way, if you spot coolant on the cardboard then its leaking if not then your Head Gasket is blown.
The milkly oil is not always gonna show up, i had my head gasket slowly go out on me. Coolant would disappear but the oil was still fine, but then one night i lost alot of acceleration and basically a cloud of smoke bellowed from the tail pipe!!
Check exhaust while car is running. If it looks like steam and has a funky odor, it's probably the HGs. It's not really a bad job to replace them. Can be done in 8-10 hours over a weekend. Upper engine gasket kits are inexpensive.
Confirmed V6 Nut
Ok, like to throw another possibility that happened to me. I blew out my intake gasket and that was where my coolant was going. It wasn't as expensive as the HGs to fix, but now I have a full Ford gasket set for the heads on up that I won't be using.
I had the same problem last year and couldn't figure it out. I had no signs of head gasket failure. On the first hot day of the season with lots of stop and go driving the temp went way up so I took a look under the hood. Coolant gushing from a hole in the bottom of the upper radiator hose. It could be a leaky hose with a hole in a spot where you cannot see. Inspect the hoses very closely. Hopefully this will be the case... $15 and less than 30 minutes will fix this problem.
Another sign of a head gasket going is the temp gage will fluctuate up & down.
How quickly? My temp gauge has a nice range to it. Maybe 3/4 up to 1/2 up when warm.
I am also losing coolant slowly. I am not too worried about it since I think I smell antifreeze in the engine compartment. I never see any on the ground though. This weekend I am going to take a real hard look at all the hoses and stuff.
Confirmed V6 Nut
richuncle,
Be sure to look very closely at your intakes. I had one coolant hose connection corrode a bit. It had to be emoryboarded and the hose clamp tighted to stop that leak, but then soon after my intake gasket let loose.
1 - 12 of 12 Posts
