1 - 2 of 2 Posts
Alright.....here it goes
So I did the T-stat install today, and did it in Auto Shop. Class ended, and I had just gotten the bolts off, so coolant leaks over a little bit, blah, blah, install it, bolt on the housing, and didn't clean up some of the coolant.
Later tonight, a little bit of steam/ white smoke came out of my headlights (only visible by my buddy outside). Could the coolant have done this? Like, gotten so hot it started to steam? There is a little of it left right by the T-stat housing. Or did something seriously get messed up? I have to put in about 4 more ounces of coolant, but that's the only thing that could be messed up. Also, can I just add coolant to the coolant 'tank' in the engine bay? Cause it says it is a pressurized system, what else has to be done?
Brian
Fry Rice Specialist
you are fine.
1 - 2 of 2 Posts
