Does or has anyone installed a trans cooler using braided hose and AN fittings without physically cutting into the factory lines. I want to use the factory cooler and the after market one but, want it to look as professional as possible. Thanks
You'll have to eliminate the factory lines al together to do that. There are cheaper and IMO better alternatives. I like to run 3/8 steel all the way from the transmission to the cooler. If you are good you can do it without any rubber line.
Alan
Is it bad to splice braided into the stock steel, even if you have the proper fittings?
Jay
Jay
No.
