I'm getting an apten chip for my 97 4.6, and I was wondering if the cooler spark plugs (ASWF-22c, i think) and the 180 thermostat make any differnece in performance. Can I get the thermostat from a NAPA store? but is it even worth the trouble? I can't imagine that it'll do much.
Not having a 4.6 I would imagine that it's one fo those things that doesn't make a seat of the pants differance, but is beter for your engine.
i think its more for the advanced timing....leaning the mixture out...less fuel to cool the pistons means that stuff just needs to run on a colder level...that or the advanced timing
I finally put colder plugs and a stat in my car after having the chip in for a few months. I changed the plugs b/c it was running rough and I thought it would be a good time to do that and then I changed the stat when I put a new water pump in. It doesn't make any difference in the seat o meter as far as I can tell, unless mine's broken, but the new stat and chip really cool the coolant down. I used to run about midway on my temp gauge, probably between the R and M in NORMAL, now it never gets to the N. And yes, it's good for the engine to run a little cooler. The colder plugs let you go a little further with timing so you can run a little pepier gas if I'm right in that (?)
MN12 Fanatic
Well when I first got my Apten chip, I had my stock T-Stat and plugs in while running 93 octane. Well the car pinged terribly!
So I got one step colder plugs and a 180* T-Stat and all was well!
I think they are more of a precationary for detonation. They recommend you use colder plugs and a 180* T-Stat, so why not?
Only cost me aboy 15 bux for the stuff and took about 20 minutes to install.
Oh and the car definatly runs cooler, especially in colder climates.
Trumpeter Extraordinaire
FWIW: My car continued to ping after installing an Apten chip. Brian (of Apten) recommended going one step colder with the plugs, and that helped quite a bit. He also programmed the chip to use the 180° thermostat set-up, and the engine runs noticably cooler...
