1 - 2 of 2 Posts
97 T-Bird, I recently blew out the number 8 cylinder cooling tube on the intake. Since then I have replaced the intake, water pump, t-stat (180), new cap, and fluid. I tested the ECT and Temp gauge sensors and they check out fine. When I hook up the OBD2 scanner it goes up to about 220 and the fan kicks on then shuts off when coolant hits 212 and it does this like a charm. Any other suggestions or ideas befoe I pull the rad. out for assumption of blockage? I dont want to overheat this summer due to something as simple as a stopped up rad. When I flushed it out it did flow pretty well, also the pressure test checked out fine.
The electric fan has two speeds. Per your description, it sounds like only the high speed is functioning. I'd start by sticking a meter on the low speed circuit to determine whether or not the fan motor is the culprit.
1 - 2 of 2 Posts
