My car just split its radiator at the lower mount of the fan. So obviously it needs to be replaced.
My question: is there a better rad I can bolt right in?
I thought about the 04' cobra rad but I need a trans cooling/heating section as I drive this in the winter too. Is the V8 rad any better/ does it fit?
Thanks in advance for the help all.
dang that sucks, didnt you have to replace the upper rad hose at SB6 in the comfort inn parking lot?
You bet, my cooling system seems to be taking a crap. Almost 115k miles though & that upper was original.
Someone has to know if the V8 rad is better & will work, come one please let me know!
I don't know about a 97, but 91-93 the rad was the same for the 6 and 8. The only one that was different was for the supercharged engine. (Due to the inter-cooler.)
Not really the answer I wanted but thank you for you help.
Anyone know if the 4.6 rads are the same situation?
their not the same
If you want to step it up a notch its gonna cost you. go with a griffin, but again, its gonna cost.
