My temp gauge keeps hitting M in Norm, if not a bit past it. I have replaced the Tstat twice, water pump and flushed the system, anyone got any better ideas? Was thinking about a 2 row radiator, but not sure it would help.
Thanks
Moderator, Red Sox Nation Rabid Fan, TCCoAAC Found
Fan turning on at the right times? Have you bleed the system correctly?
i have a similiar problem with my car. my suggestion would be to replace the engine coolant tempature (ECT) sensor. it is near the water outlet connection. there is also a sensor for the guage in the dash. it is also in the front of the engine to the left of the thermostat i believe. also def check the fan, i had the motor on my fan go out on me. i'm planning to replace the ECT on my car this weekend. i will let you know what happens.
