Ok the aircraft was KC-135A and the engines were J57-59W. I don't have the mil spec and the last time I used this stuff was 1987. If I remember correctly there wasn't a mil spec but I could be wrong. The placard on the jet never had one listed. If I find more I will pass it on. Hmmm, maybe this can help you...
link
Look at page 15 para 7.2
EDIT:
Here is out of the other tech order... Not a whole lot of info.
T.O. 42C-1-16
CHAPTER 2
WATER AND WATER-ALCOHOL IN AIRCRAFT ENGINES
a. Water with pH outside the above limits may be 2.1 WATER PURITY.
used on a maximum of three occasions per engine
provided that parent command headquarters coor- The water used for the purpose described herein must be
dination is obtained prior to use, and the engines clear and free of harmful impurities. Some waters which
are liquid cleaned according to T.O. 2J-J57-56 are suitable for human consumption are undesirable for use
immediately after each occurrence. in water injection systems since they contain a relatively
high concentration of dissolved minerals which will deposit
b. Water with total solids from 11 − 25 ppm may be as scale on internal engine parts, water regulator passages,
used on three occasions provided the engines are solenoid valves, etc., and consequently will reduce engine
subjected to field cleaning according to T.O. efficiency. Waters having a total solids concentration of not
2J-J57-56 immediately after each occurrence. more than 10 parts per million (ppm) are considered
suitable for use in water injection systems of all aircraft. c. Water with total solids from 26 − 50 ppm may be
Such water may be obtained by distillation or by chemical used on one occasion provided the engines are
demineralization. Information on the analysis of water can subjected to field cleaning according to T.O.
generally be obtained from local water works officials, 2J-J57-56 after its use.
public health offices, or educational institutions. If civilian
information relative to the pH or total solid content of local d. Any time water in excess of the pH range of 5.5 −
water supply cannot be obtained from sources mentioned 9.5 and/or total solids of 10 ppm is used, each
above, a 1-pint sample of the water in a clean glass or occurrence shall be noted on the AFTO Form 781
plastic container well rinsed with water from the same and on the AFTO Form 95 for each engine. Report
source as the sample, will be forwarded to an Aerospace to parent command headquarters any engine that
Fuels Laboratory listed in Table 4-1. Overseas locations has reached the limits of exposure to substandard
should submit samples to the nearest government-operated water (three occasions for pH outside 5.5 − 9.5,
or contract Petroleum Products Testing Laboratory for such three occasions for solids 11 − 25 ppm, one occaanalysis.
sion for solids 26 − 50 ppm).
e. No further utilization in excess of these limits is 2.2 STRAIGHT WATER APPLICATIONS FOR
authorized between engine overhaul, except in war
TURBOJET AIRCRAFT. operations and in emergency to prevent hazard to
aircraft safety. After each occasion the engines are
2.2.1 Water Requirements. Turbojet engines in pre- to be cleaned according to T.O. 2J-J57-56, as
sent, active USAF aircraft that require water for thrust appropriate.
augmentation should be serviced with water that meets the
following requirements: 2.2.3 Low Ambient Temperatures. When ambient
temperatures below 40°F (5°C) exist, water will not be • Total Solids — 10 parts per million (ppm) maximum used in aircraft that do not incorporate a system to heat the • pH range — 5.5 − 9.5
J.Miller said:
Breath in and allow me to explain. Water quality (especially in the military) is defended by its components. If you are going to say use X type of water then you need to define it. Please provide the Jet aircraft Mill specification with at some of the following:
Conductivity
Total dissolved solids
Alkalinity
Total suspended solids
CO2
pH
Possibly some base Ion requirements such as:
Calcium or simply hardness
Magnesium
Sodium
Potassium
Carbonate
Bicarbonate
Chloride
Sulfide
Sulfate
Silicon (reactive or non-reactive)
Hey what do I know? :ssalute: :ssalute: :ssalute:
