1 - 20 of 26 Posts
Ok, finally ordered my clear corners for my 95 cat. I would like to change the bulbs, which ones do you guys recommend??? I dont want them to be yellow, thats for sure.!
Israel
yea silverstars look great...gives it that blue tint while lighting up amber..
they look good on the inside parking lights also..here are some pics enjoy
-Mike
Hey Mike, looks great man, do yu know tha part number for them??? I also noticed that you changed the bulbs inside of the headlight housing, the one close to the bird, an that be changed also?
You see how you have yellow/white/yellow!?!? I want to change the bulb inside the housing.
My lighting as of now....
Doesnt that sucks??? :mad:
Off.
<img src="http://www.roverracing.com/T_Bird_Stuff/Clears.jpg">
<img src="http://www.roverracing.com/T_Bird_Stuff/Clears2.jpg">
On.
<img src="http://www.roverracing.com/T_Bird_Stuff/NewNight.jpg">
:D They're also great for replacing your parking lights, too.
First of all its the same size bulb for the corner lights as the inside parking lights. the bulb number or size is 3157.
And that lighting is pretty sad...lol..go here for some info on how to upgrade your lighting along with pics.
-Mike
You can have your headlights cleaned, too, from BigMike. Check the For Sale forum for his post.
I already got em man, just waiting for my clear corners and my hella ff75's :D
-Mike
Hey porkchop, Im about to install my hellas ff75 on my 95 man, do you have any pictures of the wiring were it asks you to clip on of the headlights cables man?
wire them up to your parking lights....cant mess that up..the headlight harness has more than 3-4 wires and i didnt feel like guessing. so wire it up to the inner parking lights. one wire is brown which is power and the other is ground *black*. just wire it through the parking light. want a pic? wait 5 minutes :D
-Mike
Pic.... :D
Discussion Starter #16
Aight man, souns good.... Thanks!
Israel
Discussion Starter #18 (Edited)
I cant figure it out man!!! Relay crimp goes inside the cabin, right??? Now. inside, I need to look for the headlight cables, the brown and the black cables, right?? Can I found a brown cable that goes to the switch when you turn on your lights, is that the cable? :confused:
Discussion Starter #19
These is what I found man!!!!! It has more than 4 cables and I also saw a ground cable *black*. Just want to make sure.!
I'd hook it up under the hood. One is a ground, and two are power. One is for the turn signal and one is for power when the parking lights are on. Otherwise, if it's a 94-97 T-Bird or any Cougar, they have inner parking lights which just have 2 wires, a ground and a positive when the parking lights are on.
When you have a relay, hook the fused power wire to the 30 pin, the foglights to either the 87 or 87a pin (same connection), the ground to the 85 pin, and the positive wire from the parking light to the 86 pin. Real easy. Most of the wires, if not all, will be with the foglight kit, like if you get it from Wal-Mart. If it's a lighted-switch kit, which it probably is, it's got the ground wire for the switch (to ground the relay), wire from switch (relay) to the foglights, and all you need is a wire from your parking lights to the relay so it will turn on. Real easy to do. Did the same thing but through the headlights on my mom's Contour. But the dims are always on, even with the brights, which you can also do. If you want to know how to do that, just ask.
1 - 20 of 26 Posts
