So I did a search but did not find a speific answer. Has anyone had this done? I can not do it myself because of time and other constraints. I think my upper rear control arm bushings are shot. How much will it cost to have them replaced?
Are you sure that you can't do it yourself? It's a real easy job. I just bought a pair back in January for about $40 ea @ O'Reilly's. Then I had the alignment checked.
A garage is going to want at least a few hundred dollars for this. Fyi, the upper control arm bushing has a funny keyed bolt hole that is off center. And this hole is too close to the edge and mine was cracked in two places.
Perch
Oops. I just rememered that I used a press to put the bushings in the upper control arm. You'd need to take 'em to a machine shop. I couldn't tell you how long it took. I replaced just about everything in the rear suspension. I still think it'd be cheaper to do it yourself.
Perch
