1. I'm planning on Seafoaming my car today and I did a search on how to do it. As I was reading some people said it was ok to put Seafoam in through the oil fill hole as long as you drain your oil and others said not to because you would have to pull your pan. They were speaking of sludge getting into the oil pickup. I don't want to pull the pan so is it safe to pour Seafoam into the oil and how long do I let the car run if I do? The car has 179k miles and was getting an oil change today so I figured I'd give it a shot.
2. I am planning a PI head/intake swap for next spring/summer. When I finish the swap will I need to get a chip right away or will the car run fine for a few weeks till I get the money to get a chip?
Thanks!
Thanks!
