1 - 14 of 14 Posts
What is the size and pitch of the crank damper bolt? Thanks!
-Rob
I need a longer one. I apparently lost the one to my other piggyback set.
-Rob
10.9? Could you clarify a little more? Thanks!
-Rob
Formerly Fdawg97LX
the tourque specs for the crank bolt on my 97 4.6 was 118-121ft lbs. maybe the 4.6's need a little more than the 5.0's?
Frank
I have the longer crank bolt. M12x1.5x80 10.9 is what you need. You can't find it many places w/o getting a fairly large order. If you want one let me know.
<img src="http://members.tccoa.com/94birdnj/marchbolt.jpg">
Heavily Medicated Crime Fighter
Frank, You sure it was that high on the 4.6? Well it that is the case and you REALLY need a high end fastener.
Rob,
The grade 10.9 is a metric grade and is equivalent to the standard grade 8 fasteners. BTW the metric 8.8 fastener is in no way as strong as our grade 8 as one might think as that rating is equivalent to the standard grade 5.5 and should never be used where a hardened fastener is required.
Regards
Mark
Formerly Fdawg97LX
yea it was actually 114-121ft lbs not 118-121. it is pretty high. i reused the stock bolt when i did my underdrive pullies but i'm gonna be installing cams probably this coming sunday or the sunday after that and i'm gonna replace the crank bolt then. where can i get one? do i have to go to ford?
Frank
I always just tighten the hell out of it with a 1/2" drive impact wrench. :D
-Rob
ARP makes a crank bolt for the 4.6.. I don't know about the 5.0
Formerly Fdawg97LX
thanks for the info, where can i get one?
Frank
02 Explorer Pioneer
I also read over on MD recently that it is a TTY bolt so 1 time use for the stock one don't know about the longer one supplied with UD pulleys
Frank
For the stock 4.6 Crank (Damper) Bolt:
Summit Racing... PN: ARP 156-2501 ... $17.95
Here's the link to order on-line ARP Crank Bolt / Summit.
Jegs probably can get it too, but they don't have it listed in the catalogue or on-line.. Their PN would be 070-156-2501 most probably...
-mike
Formerly Fdawg97LX
thanks mike.
Frank
1 - 14 of 14 Posts
