How do I test the crank Position sensor to see if a signal
is being sent to the computer?
No spark at the plugs.
I want to check for a broken crank sensor.
Discussion Starter #2
Fixed.
What's the first thing anyone should check first?
Loose wire.
Rick
Since you brought up the subject... What is it exactly that fails on or going to the sensor causing the no start condition?
Reason I ask is my cougar would crank, and not turn over last week. I unplugged the crank sensor and plugged it back in; problem solved. I cleaned the connection with contact cleaner after as well. From what I could see the connection looked clean though so I don't think that was the issue.
Is it just lose wire? It's in a tight spot so I haven't taken a really good look into it yet.... Would like to fix it so this doesn't happen again. So far its been fine though
I'm betting the wires near the end of the pigtail are corroded and/or brittle causing an intermediate open or short. When you unplugged and replugged it you probably got the wires in such a position that they regained good contact, ala the wiggle test.
I had this happen to me a few years ago on my original 96/7 harness, had to push the car back home two blocks from where it died :rolleyes:
