Well guys, I pulled out my crank sensor tonight. I'm running a AC delete kit from Ford Parts Counter on here, its a factory ford part. I do have the radiator and the fan out for other repairs. The bolt is JUST to long, so I had to remove the pulley, just the pulley from the delete kit, then it pretty much just fell out, sensor and all. It's pretty gravy, I may just grind a little off that bolt, it actually sticks out of the other side of the front cover anyway, then I wont even have to take the pulley off to get the sensor out.
I know a bunch of you guys asked about this, so I figured I'd post what I had found, hope that helps out,
Brandon
MaleWhore
how much that ac delete cost u?
I got it off of FordPartsCounter for $20, he was running an old stock sale or something. He may have some left. Saves a TON of weight.
