What size is the bolt that holds down the crank sensor? Also, what size are the bolts that hold the A/C compressor on the block?
Do you need some I have some extra if you need them just cover the shipping! If not I'll go check to see what sizes they are!
Are you asking for length and thread/pitch or do you need to know what size the bolt heads are? I don't know the length and thread/pitch off the top of my head, but the bolt heads are 10mm for the AC compressor bolts and 8mm for the crank sensor.
-Rod
