hey i pulled the plugs because the crank wasnt turnin.so i crank it with the spark plugs out and no air blows out does that mean the crank it broke?and it blew air out the right one near the back.then no more.the starter turns the flywheel...any ideas?
Fry Rice Specialist
pull valve cover and check the rocker arm?
or do some compression test?
has the engine been sitting for a long long time? could the rings be stuck in the cylinder?
so do you guy for sure think that that the problem?and does anyone one know were i can find one?the motor is a 99 5.4 triton
www.car-part.com or do yourself a favor and get rid of that dumptruck motor for a PI.
