Creak/clunk sound from front right suspension.
’97 T-Bird makes what I would describe as a mix between a Creaking or clunking sound. It sounds like it’s coming from the front right suspension. It’s most noticed at low speeds when, breaking, going over mild bumps or turning the steering wheel when moving slowly. Turning the steering wheel when the car is stationary doesn’t result in the sound.
Here’s the work that was done about 15k miles ago:
  • Strut rod bushings (left and right).
  • Lower Ball Joint (left and right).
  • Front inner tie rod ends (left and right).
The Upper Control Arm (left and right) was replaced about 25k miles ago.
The right side sway bar link was replaced about 70k miles ago.
Can anyone help me figure out what is causing this problem? How do diagnose etc? :confused:
The left side sway bar link was replaced 15k miles ago. I just didn't mention it since the noise is from the right side. Breaks were also done 15k miles ago. I'm not sure if there are any other front right suspension parts left that haven't been replaced but I'm not a suspension guy! I was expected the suspension was good to go for awhile. :(
Lay a weather eye on the sway bar bushings also.
Depending on the parts you've used, they're all suspect. I have a creaking on mine as well and In the last year I've done the lower control arms, tie rod ends, sway bar links, bushings, upper control arms, shocks, shock mounts. You name it and it's been done. All moog or TRW, and now it's creaking.These cars just hate us.
Can the Lower Control Arm cause this kind of problem? I see there is a ball joint in the LCA.
The sway bar link has about 70k miles on it. Is there a test I can run to see if the sway bar link is at fault?? :confused:
Look at the boots, they usually tear and allow water in, if they're torn they're toast. Also noises under these cars travel, check your rear links, i've had rear ones go and it sounded like the front. There's a sticky on this forum for clunking under your front end, it's good reading.
When I purchased my 1997 T-Bird, I was able to negotiate a (significantly) lower price than what the seller was originally asking due to a HORRENDOUS knocking/banging sound the front suspension was making while I was driving the car, especially over bumps. We thought there was a serious problem with the front suspension.
It turned out to be only severely worn front sway bar end-links. Worst noises from a suspension I've ever heard! I replaced them (with Moog) almost 65,000 miles ago, and never had a single problem since. I would suspect them, or one or more of your ball joints.
