i have a 93 tbird and just recently it starts to creek pretty loud when i turn the steering wheel either direction. i had most of the suspension redone about 4 years ago so depending on what it is i can get it replaced under warranty. also when i brake my car veers to the left. now ive changed the brakes and calipers twice already so could it possibly be the suspension causing it? thanks.
-David
My car creaked pretty loudly while turning when my lower control arm ball joints were on their way out. Did you do the work yourself? I would recommend looking at all your ball joints, and seeing if anything else is loose. There is a sticky about different items to check.
MAMN12 Posse Member
I had both of those same problems. It turned out to be the control arm-to-frame bushing on the driver side. Sounded horrible when turning the wheel, and when you'd touch the brake, the car would pull that direction.
I ended up replacing the whole control arm. They sell Moog replacements at Advance pretty cheap that includes the control arm bushing, strut bushing, and lower ball joint. Just add a set of strut rod bushings while you're there and you'll be good to go.
Oh, and a realignment. :)
Driver's side LCA.
Brenda's Cougar did the same creaking, and pulled to the right under braking. Replaced the pass side lower control arm, and all was good!
Al
