I have searched and read through all of the threads relating to cruise control and i did not find what i was looking for. I do not have cruise or a horn, all fuses check good. I do have the FR500 steering wheel with mustang cruise control buttons and horn contacts. I have already replaced the clockspring as well. Also If some one could load a scan of the cruise wiring diagram and pinpoint tests that would be great.
both in mine are dead as well. has your airbag been deployed? both mine worked fine before my wreck.
no cruise was fully operational until about three months after steering wheel swap. Air Bag circuit is complete and there are no lights on the dash.
next time you have your airbag out would you mind posting the part numbers? I have no salvage yards in my area to rummage through. Do you think that if i ordered the horn contacts and cruise buttons for a 97 V6 that they would match up being the same year?
My cruise control doesn't work because I don't have the correct speedo gear for my rear end. I can't get a 2.73 speedo gear :(
I don't recall seeing any part #'s, but I'll remember to take a look next time I dig into it.
I think my bad harnesses were off 94/5's (except the non cruise harness I was using for a while, the horn worked fine from and was from a 95 gts). I would think that a 97 setup should work, but not 100% sure.
Cruise control functionality has nothing to do with whether or not you have the correct speedo gear. The speedo gear only gives you the correct speed.
