So today while on my way to asheboro I set the cruise at 70 and a few seconds later I look down and notice my speed rise a few MPH. I don't really pay much attention because I was descending one of the hundreds of hills in that area. I get a phone call and I'm concentrating on the phone (I really shouldn't do that I know) and im starting to pass people at a pretty steady rate. I look down and am approaching 90! :confused: So I tap the brakes to shut down cruise, no response. I hit the "off" button, still doesn't cut the cruise. I even hit coast, the throttle blips for a few second and then picks right back up. I had no choice but to hit the flashers and get off that highway. Put the trasmission in neutral and my engine is revving at 3k and climbing steadily. So I cut the ignition and coast to the side of the road, cussing the car the entire time. Once stopped I start the car again. I crank on it for about 5 seconds before it fires up and as it does engine RPM's rise steadily. I shut down the engine as the RPM's hit 2k. I'm at a complete loss here. After starting the car up a third time everything was normal and as it should be. I wasn't about to try cruise again so I finished my 400 mile trip with my right foot. What on earth could this be?
I was thinking maybe a faulty cruise module? The TPS? My butterfly valve is sticking in the TB but not enough to make the car accelerate steadily...or atleast I don't think so.
Any suggestions?
There is a recall regarding this. If anyone remembers, it happened to the President's Lincoln quite a few years ago. Search around here and Google, I'm sure you'll find other experiences like yours - you're not alone...lol
One thing you can do for the time being is disconnect the cruise control cable from the throttle bracket on the plenum.
This cruise control switch recall by Ford has been going on for over 20 years, no exaggeration. The lastest is Ford Trucks. Here is a link about the 1990s vehicles, cars and trucks:
http://www.newsinferno.com/archives/2517
The recall on the faulty cruise-control switches involves vehicle fires and has nothing to do with the OP's problem with his cruise-control.
