my cruise control and horn both stopped working at the same time. i checked the hazard lights and all work but the rf but the rf blinker works. im not getting any blinking airbag lights like some people with the other 2 problems. would this be the clock spring? or anyone have another idea of what it could be.
Confirmed V6 Nut
Check your connectors under the dash. There are 2, one huge one and a smaller one. Make sure they are tights.
Also, check your connections from the steering wheel. Your hazards, blinkers, high beam switch, and wipers are controlled by the multifunction switch, and are not in any way functionally connected to your horn and cruise.
Have you checked the fuses?
Jay
Check the ground connection on the front end, right in front of the radiator.
On my 92 SC there are about five wires that clip onto a 5-spade terminal. I had to clean the gook off and my cruise started working fine.
