My 97 v6 3.8 Cruises at 70 MPH 1500 RPM.
This seems low compared to my Honda 4cyl. which at same speed stays at 2500 RPM or a little lower. What are your readings? :cool:
it's all about gearing and powerband. the honda high a much higher redline.
Seems a little low. I would say 1800-1900 is about the norm at 70 mph. That's what I usually run with my 94 4.6 LX. My buddy runs around 1900 with his 93 3.8 XR7 (stock everything).
for me, 70 mph = 2100 rpm (3.55 rear gears and 215/70R15 tires)
5000 rpm at 71.7 mph (on my bike, with a 13750 redline). :D
I believe the Thunderbird is in the 2000 - 2200 rpm range at 70 mph (CA car, has the 3.27?? gearing). I could be wrong though... I never really pay it any mind.
snap2 said:
Did a retest tonight and got 1999 at 70mph.
Are you sure it wasn't 2000rpms? haha. 1999 is a pretty accurate reading.
Smaller engines don't produce much torque so they need to run at higher rpms to be able to get the hp's. Hondas are geared acordingly. The final drive of a typical Honda is 4.11 or above.
3.27 gears and an AOD.
My tach says 1550 rpm, but my calc says 1950 rpm. I wonder which is right.
