1 - 11 of 11 Posts
I had several sets of these made a couple of years ago. They work good and you will notice more vibration.
This set is not finished, to finish them you can use a threaded rod and jamb nuts on either side, loctite everything together and they work great. This is how I assembled them on my car. You could also tap the hole and use studs on either side. These should work on any v8 car, I do not think the v8 and v6 are interchangeable.
I am looking for $75 shipped to your door.
They are aluminum and they weigh 1lb 12.5oz. Are you asking about what type of aluminum, because I am not sure I still have that info?
Ok, not be THAT GUY asking the stupid questions...
So we just replace the rubber bushings in our existing mounts with these things?
No, these completely replace the stock mounts, you will have to use a threaded rod or tap the holes for a stud to mount them. You will notice some more vibration but not a great deal.
Bump, if somebody was interested in becoming an AMSOIL Preferred Customer it costs $20 and I will send you the mounts for signing up. Just trying to get creative so I can get rid of them.
Preferred Customers save 25% on all AMSOIL products.
1 - 11 of 11 Posts
