I just found a set of 5 spoke American Racing wheels, 16x7, with center caps, decent tires, 45 minutes away and only 80 dollars!!! they have the 10 lug holes for the dual bolt pattern. So I call the guy up, and it turns out, he took them off a beretta :[ dang it all
And?
What is the bolt pattern of a Baretta?
What is the other bolt pattern?
I guess I don't get what you're problem is...
If the uni lug pattern fits a 4.25x5, then they're good, if not, forget it. Unless you've done a mustang hub swap on your car.
i was griping because I found the wheels I want semi local for a great price with the wrong bolt pattern.
they are dual bolt pattern for GM :[ so that would make 5x100 (beretta) and 5x115
If You do a mustang hub swap..
You can use nearly any/every rim out thier!!
that's true, but this was the particular style of wheel I want. not to mention theres someone on this forum that has a set of them for 230 shipped. which would be a LOT cheaper than doing the mustang hub swap. lol, and I can't even afford the 230
