I had a 93 3.8 cougar for a long time - has over 200K now and isn't really being used. My problem was that it had a dead spot when I'd give it gas. A very small dead spot immediately when fuel was applied. It'd sputter and even die sometimes. But once it got past the dead spot, ran perfect. The thing got 28 mpg it's whole life. Cold weather usually contributed to the problem. Also, it idled crazy sometimes, sometimes not. I replaced every sensor in the car and had it checked on the computer several times. No cure. I've tried for years to fix that problem and kind of gave up on it.
I recently bought a 91 5.0 builder and the mechanics of the car are great. Having driven it for 6 mo's now, i'm starting to notice mild symptoms similar to my 93. The ever so subtle studder right when i touch the throttle from a stop is there now? There's no check engine codes. How can two different engines have the same brain racking problem? I hope someone has experienced this and figured it out. Thanks!
Matt
Matt
