If one wanted to delete cruse control on 95 4.6 those vacuum lines comin for booster you can block off, but what about the one going into the inner fender into the car? Can u block that one or what does it go to thanks.
The one that goes into the passenger bay is the vacuum dump valve, and can be ignored if yhou're deleting cruise.
Passenger as in the inside of car right? Because the cruse an the lines I'm referring to are on the drivers side. That that dump line need pluged or anything?
Hence the phrase "passenger bay" - yes, inside the passenger area of the car.
It goes to the dump valve on the brake pedal, and as such, only has "vacuum" when cruise is running.
