Refrigerator Raider Hater
You can send him the computer, or he can mail you a chip to keep downtime to a minimum. It's not a tune unless your on a dyno, and his is adjust fuel and spark. The reflash/chip is only a base tune that will work on your engine.
P.S. The "base" program is the best out there, excluding an actual dyno tune.
Sheepish
Hmm, good luck with the EEC tuner, and keep this in mind. Chip tuning is no child's play. One false setting or if you try using to agressive tuning and you can kiss your engine goodbye. You also stand the chance of getting everything so far ut of whack the car won't run at all. Just be careful if you decide to go that route...
Sheepish
Dude, that caps hurt my eyes. I honestly find them hard to read...
Dr. FrankenCougie said:
Tuning your car with an EEC_tuner is allot harder then typing correctLY. How will you make sure your A/F is right? How about the MAF Xfer function?
Clue a get.
Yoda is to Jedi as Scott is to Cougar owners. Sounds right to me!
CAPS______Me
