1 - 13 of 13 Posts
Hey guys, I have a 96 bird. The car starts and runs flawlessly, but it dies the second that you put the car in drive or reverse. This started all of a sudden without warning. Car is stuck, cant move it. No check engine light. I havent changed any sensors yet. I was thinking tcc solenoid. I dont think its the transmission, at least not a hard part. This is Darrins old bird. Ive been driving it a little the past few months and it has shown zero signs of impending tc or trans issues. Does have a marauder converter. I was driving it very gently when this started and it had been driven very gently the last few months. It hadnt been over 3k rpm and honestly its usually driven at 10-20% throttle so I doubt I broke anything. Help me out fellas, I love this car and I hate to have to pay to flatbed it to a repair shop and look like a fool as they rob my hard earned $. There is no code and its had a complete tune up( all filters, plugs, wires). Could this be a weak fuel pump? It does start and run flawlessly.
When you put it in D or R it dies hard. No sputter, no chance of keeping it running so thats what leads me to think converter or tcc solenoid. I have checked every vac line and wire. What next? Thanks guys
If you think the converter is locked all the time, can you get the car rolling a little and put it in gear? Or maybe start it in Neutral, give it a little gas and shift it into Drive? This is just to verify what you suspect is going on.
When I first saw the title, I was thinking you were saying it died cause it would idle so low - I've seen that before. I've never seen a Ford with a locked converter, but I have seen a Chevy like that.
Thanks. Unfortunately I cant get it rolling by myself & I have no help.
Theres no keeping it running at all in gear. Dies hard the sec it is placed in D or R. Like you turned it off. Could a bad tcc cause this? I havent been able to contact Darrin, I usually bother him with any questions. He built this tranny and its a bad boy. Im sure its not anything mechanical in the trans. Maybe that solenoid, maybe a failed converter. Its a marauder unit. Im about to give up and pay $200 to have it towed to a shop so they can tell me im f****d. I figure its a wire or bad tcc and the shop will diagnose it as a bad converter so ill spend a ton of $ for nothing. Somebody tell me what to do next. The car runs perfect. The drivetrain is awesome but just outta nowhere it dies when u put it in gear. Any way to disable that tcc solenoid? A wire I shoukd check? Lost here. Thanks guys
mine did the same thing, and i was suspecting the TCC solenoid as well. never did figure it out though, the trans was wasted and slipping in first anyway so i just swapped the whole lump.
can you get the RPMS up to like 3k and drop it in gear to go? i know i know... ouchy... i had too do that all the way home from college when mine started this :D of course i wasn't worried about the trans, if this is darrens car then its bound to have a nicely built monster under their you probably don't want to neutral bomb too much :tongue:
like mod said, get it up on some SOLID stands, and some chalks under the front wheels and try the gears like that. if the wheels are spinning like mad at idle then your TC is most likely staying locked.
otherwise, i would definitely start with a TCC solenoid and a fluid change before you dig into anything serious. cheep and simple.
I really appreciate the help guys. I will get the rear end up and see what happens. If the tc is wasted then will it still die as soon as I put it in gear? Or should it start spinning the rear tires? And yeah, I wont neutral drop it. Tranny is strong & its a bad boy. Im certain it is something to do with the converter, hopefully somethin minor. I will update you guys the minute I know anything.
Mine did the same thing I'm sure u can find a post about it. I reset the battery and it ran fine. Don't no what happened but it worth a try. Then about 3 months latter it started happening a gain so I cleaned the iac vaule and it stopped. It drove fine untill I toasted the tc. I hope u get her running again.
Thanks buddy, how long does the battery need to be unhooked? I let it sit about 30 mins unplugged but no change. I will try cleaning the iac. I want to exhaust every option before I tear it apart.
Sure sounds like the converter is not unlocking. DirtyDog and I had that issue on one we put in my car once (long story).
My worry would be why it is not unlocking. It could be as simple as a bad TCC solenoid, wiring issue, etc... or it could be as bad as a loss of pressure in the TCC circuit.
I am hoping to find a loose/bad connection but I dont see anything obvious. It will be monday or tuesday before I can get the car inside and take it apart . No codes showing. I take it a failed tcc solenoid can cause this? I really think the trans is ok due to the fact that it never once acted weird. The tranny and the tc functioned flawlessly until all of a sudden. My understanding is that the converter itself can fail suddenly and unexpectedly without warning but I would think it wouldve showed some kind of symptom prior to this. It was just cruising down the highway. Car hadnt seen more than 3k rpm even once recently. This all leads me to think that this is likely not failure of a hard
part but more likely a switch/sensor/wire issue. Its all speculation until I can get it rolled up the hill into the garage & I need help for that. Just cant get it in the air up next to the curb.
Good idea Driller, I just called, its $30 so theyre on the way now. I could deal with the cold and snow but doing much work to it at the curb in my neighborhood would be kind of dangerous, make the neighbors mad & just a pain in the ass. I have been dying to work on the car and its killing me sitting out there. I never let it sit unprotected and I keep it off the nasty salty roads here. Driveways pretty steep but should be easy for a rollback. I hope to have some good news this evening, will update.
Just to update. I took it to a shop. They say the torque converter is bad.
I would question that but ive known the shop owner for years and he diagnosed it himself.
Its a stock 2004 marauder tc. Locked up without warning. Been in car about 2 years and didnt have many miles on it. Who knows? Gotta weigh my options now, they want a small fortune for labor to change it.
1 - 13 of 13 Posts
