Is there a difference between different years, what ones can I use
Thanks
Will
Formerly Fdawg97LX
96-98 gt tube is the same as the 96-97 tbird. 99-01 gt tube has a small hole in it to put the air temp sensor in it and the 02+ gt intake tube is the same as the 99-01 but without the hole cuz the 02+ maf has the air temp. sensor integrated into it.
Frank
Are all of the 99+ useable for a GT tube?
Formerly Fdawg97LX
yea 99+ are all the same except for the hole for the air temp sensor. it really depends on what maf your using. if your using an 02+ gt maf, then you need an 02+ intake tube. any other maf you need a 99-01 intake tube.
Frank
