· Administrator
1994 Cougar XR7 DOHC/5-Speed
originally posted by fast86rx-7
is it possible to swap the digital hvac controls from a 95 into my 96 i would rather have them or will it ba a wireing nightmare?
wait, are you asking if the digital controls can be swapped between a 95 and 96, or are you asking if the manual ones can be converted to digital?:confused:
· Very nice... How Much?
if the maual to digital was easy everyone would do it... is it even possible ?
· Registered
its possible, its swaps in the.... "well it fits" sense but after that I can't even begin to think of the problems involved
· Administrator
i've actually considered converting to the digital climate control, and from what i can tell the whole dash harness would have to be swapped from a car that has it because there are two 13 pin connectors for the controls that are not there, and i think the ducting and blower motor may have to be swapped as well. however, i did notice that the outside temp sensor connector is on the engine harness in front of the core support, but thats the only thing i have found that has to with the system.
so its possible but finding the parts, getting the parts, and swapping in the parts(if they even work) will be a royal P.I.T.A.
· Premium Member
fast86rx-7 said:
sweet are all the wires there for it to get outside temp and inside temp?
Guess you misunderstood my answer;
Yes, it is possible to swap etc.
Yes, it would be a wiring nightmare.
From the people who have tried it, they do not recommend it.
