1 - 2 of 2 Posts
i was looking and it is a dark dark green and looks very dirty, some 1 said there might be oil in it, what should i do?
its probably just corrosion if you haven't been keeping up on flushing the system.
Here is what I like to do, drain the entire system, and take out the overflow bottle and scrub it with a cleaner, and a toothbrush to get all the brown crap out of it, then rinse it real good.
Then just flush and fill with prestone and distilled water, and you are good to go.
Its a good time to replace the thermostat also.
Also inspect the radiator hoses and heater hoses and replace as necessary.
JH
1 - 2 of 2 Posts
