1 - 15 of 15 Posts
Hi,
Do the strut rod bushings (MOOG K8680 and K8659) come in pairs? (i.e. do I need to order 1 or 2 of each to do the whole car?). They are $20.79 and $36.79, respectively, from Rock auto.
I read a ton of old posts on this and it seems that most of the posters had bad LCA to strut rod bushings. Has anyone had the OEM strut rod to K-member bushings fail? (I know about the MOOG failures)
Lastly, has anyone ever found out if the LCA's for the Mark VIII are the same as the T-Bird? The T-Bird ones are 1/2 the price. Any concensus on this?
Calvin
97 Mark VIII LSC
03 Navigator Ultimate
Well when you buy them from ford you get in one package 2 fronts of the LCA and you need to buy the rears too they also come in a pair. So when you buy them you have to order one set for the front and one for the back and it will take care of the 2 strut rod ends that go through the LCA. As for the moog ones i really dont know
Thanks Matt,
Does anyone know about the MOOG's from Rock Auto. I just want to be sure before I order that I'm getting the correct stuff.
Full Metal
IIRC, i think the difference in price is because of the material they are constucted of, the mark's control arms, i believe are aluminum, the thunderbird's is not.
Yes, the part numbers are MOOG K8680 and K8659.
Chapter Director Coordinator
the moog strut rod to frame bushings are a whole kit for the front
i bought TRW strut rod to LCA individually.. so i don't know there, but i think thats a set as well
well.. i did.. but i used the stock "washers" instead of the small **** they give you..
I thought these failures were attributed to using the 3" long sleeve -vs- the 2.75" version???
Overkill Fetish Freak
"I thought these failures were attributed to using the 3" long sleeve -vs- the 2.75" version???"
Even with the "fix" they only lasted 2 months at best on Cougie. I do take the car to the extremes in the mountain turns so take that into consideration.
seems better off just getting oem ones
read further into it....the ones that are failing are on the driver side right under both power steering and transmission fluid lines, how do i know this? 2 bushings blew out in under 6 months. Its the thermoplastic that is a problem.
joseph
Discussion Starter #15
So I guess the key is to insure that the bushings stay free of oil based products?
1 - 15 of 15 Posts
