my old ladys friends has a 1993 dodge shadow. she says when it gets warm it starts skipping and shaking alot and she had to keep the gas on or it will stall out. anyone know what might be wrong with it? thanx
Mass Airflow Sensor To test it, turn the car off and unplug the MAS. If it idles fine, if a little bit rough, then it's the culprit.
Those year Dodges are very easy to diagnois. With the engine off, click the key to the On postion 3 times. Now watch the check engine light flash.
It will flash codes. 5 flashes, pause and 5 flashes is 55.
Compare the code with a list and start there.
You can probably find a code list at Allpar.com
