I was looking around on a local site and saw this thread . At first I thought it was just another DOHC swap in a fox til I saw the distributor. If you read along the thread, he says that it is a Mark motor, obviously he put a Cobra intake on it.
You need to be a member to view the above link. But I assume, that this is what you are referring to.
From X2Cmotorsports.com
Description:
Our distributor drive system is great for race cars wanting to run a standard more powerful ignition system than the weak factory coil packs. This system can be used with any coil or ignition system and includes a custom billet msd distributor available with a magnetic pick-up 2 wire distributor, a TFI style distributor or a distributor set-up for use with a crank trigger. The kit is an easy bolt on and is ready to run. (Wires not included)
Johnny Five is Alive, TCCoAAC Member
I think that is funny..
You can get a MageJolt Jr and just use EDIS.... http://picasso.org/mjlj/
And.. I am in the process of putting EDIS on my 5.0... (using the EDIS8 Box, and A9L eec)
