Interference, just like the 2v is. I can tell you this for sure since I had a little PTV contact situation when I had my LH cam off by like 30*. You should probably at least read the sticky at the top of this forum if you want to know all the differences of the 4.6ls. I havent read it in so long so I dont know if it covers the 3v heads yet.
-Rob
Also, probability is high that the engine has other issues. Snapped timing chains aren't common occurances with these engines.
It was going to get torn down any way maybe ill just use the bottom end and build a teskid/ PI 2 vavle engine combo. (300 for the whole car wich was black on black with a beutiful interior is a good deal IMO)
Thanks for the help and quick replies
