I wanted to see if anyone had any ideas. For as long as I can remember the SC has sounded the alarm if you open the door on the drivers side with the key and not the keyless entry. Passenger side is fine, can unlock with key and everything is good. No alarm. Any ideas that would cause the drivers side to alarm when unlocked with the key. Thanks for anyone’s help just signed up.
IIRC, there's a secret handshake; you turn it all the way one way, then the other, to disable the alarm. Disable alarm, other way was unlock.
Ya figure a switch that's been switched once in 20 years will still work? :)
That's likely the issue; I think the procedure is in the car book.
The code is printed on the side of the trunk support, I'm pretty sure.
And it's printed on the side of the box in the trunk.
