I'm thinking of replacing one of the doors since the bottom is so rusted out and it isn't as straight as I'd like it to be. Is there one connector that can be undone for all the wiring that goes from the car to the door? If so, where is it? Do I have to cut all the wiries instead? Thanks for the help.
3rd Gear Chirper
No cutting but I think you have to go into the door and disconnect everything individually. I've never seen such a connector for the doors only.
Yep, there isn't a connector. You have to feed all of the door wiring out the hole on the front of the door.
-Rod
