ran a detailed search on DRAGON products to no avail. Any experiece good/bad/indifferent with the dragon upper plenum or t/b ?? Planning on finally swapping out my combo on my '96 with accufab and etc. etc., but was just curious about dragon.
thanks guys/gals !! :)
To me it was worth it to save and get the Accufab, but then again I only had to buy the plenum. Do a search on MD and you will see the review done on all the available TB's and Plenums.
yup, found it. lot's of good info over there. :thumbsup:
According to the tests on the MD, the accufab upper and 75mm TB was the best
overall combo. It was also the most pricey however.
Steve 4.6L
There is no gain by stepping up to a 75mm TB instead of the 70mm TB on a NA engine. If your plans include a blower in the future then by all means get the 75mm. That should help you save a few $.
Yes, there is a price difference, but if you are going to spend a good junk of the price of an Accufab for another product that doesn't gain as much it becomes a personal preferrence if the amount you will gain is worth the extra cost.
Should be able to get the combo dlvd to you for $400.
