Ok dont b---h slap me here.
Spoon feed me on how to run the fuel pump without the engine running?
I want to drain the fuel tank without removing it.
I disconnected the fuel line after the filter, attached a hose to the filter outlet and ran it to a gas can. Then just ran a small wire from the positive battery terminal to the fuel pump wire on the passenger shock tower (inside that rectangular plastic housing) and just probed it with a needle to give it 12V. This turns on the fuel pump relay (low current) inside the ccrm which is already grounded.
You'll have to wait for someone who has the wiring schematic for a 94/95 to chime in and tell you what wire color you need to probe, as I have a '97.
Unplug inertia switch and put power to the black pink wire
