OMFG I can't get this thing off! I've sprayed "PB as seen on tv PB Blaster" on it every day for three days, then heated it up with a tizorch. This MFer will NOT come off. Any suggestions, any previous experience with this?
oxy and blow it off
oxy/acetelne torch , cut it off
Dremel with right-angle drive attachment, plus approx. 1 1/4" dia. grinding disc.
Cut almost all the way thru one side of the nut, then split it the rest of the way with a flat blade screwdriver.
.....worked for me..........
