Im in the middle of a swap to a Tremec 3550 trans, and if any one else is looking to do the same thing the stock driveshaft length is 58" from center of u joint to center of u-joint. Youll need to get the stock one shortend, or even better a new alum one, 1.5" with a 28 spline input shaft, the stock one will work unless you get a TKO or the 3550 II. I hope to dip into the 13's on the nitrous, with the stock auto a friend of mine with a 02 GT 5-speed with 4.10's only pulled a car and a half by the time i got to 100
Josh
Josh
