Hi Everyone,
Has anyone tried to balance their stock driveshaft vs. buying a Mark VIII or aftermarktet one? Any benefits, drawbacks, opinions? I ma going with 3.73s, so eventually I will need to do one or the other. Thanks!
Don't bother balancing the stock shaft. It's not about the balancing. It's about length, diameter, material, construction, rpm's and harmonics. ;)
ever see the effects of high RPMs on imballanced steel? Even worse, higher RPMs on a ballanced steel disc? Quite impressive, 3lb disc at high enough RPMs can put a hand grenade to shame :evil3:
Aluminum = less rotating mass = (tiny tiny) gain in rwhp ;)
