1 - 2 of 2 Posts
How does this driveshaft from SCP compare to the older MMC? I thought that the MMC was balanced to 8000 rpms while this is 6000.
4" Diameter 6061 T6 High Performance Lightweight Aluminum Driveshaft from Dynotech
http://supercoupeperformance.com/partBrowser.aspx?category=27
The plan is for a 3.73 Torsen Diff. Thanks.
If you're talking about the metal-matrix driveshafts.. they're made of a slightly different material. MMC is supposed to be stronger than the plain 6061-T6 shafts. I believe Denny's driveshafts makes a MMC and a comparable 6061-T6 shaft. Depends on what level of reliability you want and how much you want to spend.
1 - 2 of 2 Posts
