brake lights come on, the turn signals work, so do hazards. but when the headlamps are on, the lights, running lights whatever dont come one at night. only when i used the brakes.
i am not sure why.
i checked the bulbs, changed em out, looked at fuses, nothing wrong, so loose wires.
maybe the switch, bu which switch?
i am not sure why.
Check your ground wires
theres like three different grounds in there
but they were good, turned out the tag lights were burned out, and the led apc light i had in there before burned my rr/pk lps 10a fuse
freaking apc, i used nightshades so i needed brighter bulbs, they only got me ticketed twice.
once for not visable, and once for no running lights
i had a 90 tbird and the dimmer switch was weird> turn it to dim and it dimmed the outside back running lights turn it to bright it lit the lights in the back to bright > i found out after being stopped by the police going to work...i would test that to see if it helps not sure why it was wired that way?????
i knew a guy that had a 89ish f150 that did that turns out he wiered hid cd player wrong that will learn him for not buying the wire harness:cool:
Dim Bulb
Sounds like somebody did a hack job on some custom wiring, a plug/wire was shorting out, etc
High-Mileage 4.6L Thrasher
A bad multifunction switch can do the same thing.
JL
