1 - 12 of 12 Posts
First of all, hi everyone!
New to this forum, I've been a proud owner of my '97 4.6L LX Limited Edition T-Bird for almost ten years. I recently tried to install the Daytime Running Light module and found after a lot of research that it should be pretty much plug & play. It should be plugged into the C186 located on the driver's side fender somewhere and the fuse should also be plugged in. I brought the car to an electrician who said after searching that he could not find the C186 plug and the DRL fuse slot is probably not even wired. Does anyone know if that is actually possible? Or could anyone provide a picture where the plug is visible?
I assumed all the 90's Fords would be pre-wired for the DRL module. I had a '98 Taurus before the Bird which had it installed and activated and worked perfectly.
Any help would be highly appreciated.
Best Regards, Fabian
They were only pre-wired for DRL in early supercoupes IIRC, definitely wouldn't be in a US spec 97
Thank you for your quick reply. I guess there is no easy way to have it installed even by someone who knows what he's doing? Unfortunately there was no manual or schematics showing which wire should go where...
There is a schematic in the EVTM; I'd grab a set (EVTM and FSM) off Ebay.
Thanks a lot Ralph. Just checked, the shipping to Europe is extremely expensive for these heavy books... :surprise: Since I only need the wiring for the DRL's it's some kind of an overkill. Together with the module and the custom built harness and plugs necessary these would get too expensive.
Would anyone be so kind and willing to share a picture or a scan just of the DRL section for me? This is a lot to ask I know but I don't think I can get hold of the EVTM & FSM over here...
I'll snap a pic of mine this afternoon.
Not all year EVTMs have the DRL diagram, my 95 one does, my 96 one doesn't, and I imagine 97 won't either.
Thanks a lot, that's very kind of you. Didn't they export the 96 & 97 T-Bird to Canada at all? As I understood they all had to have the DRL working at that time - probably still do? I guess with LED's these days? I'm wondering why your diagrams don't have have it included because they said the module will fit the 97 where I bought it (rockauto.com.) Sorry but I'm very confused... :laugh:
I know the automatic DRL's were mandatory for a number of years, but I notice new cars don't seem to have them anymore? Are they manual instead of automatic now?
None of my cars have DRL's.
Al
1994 Cougar XR7 DOHC/5-Speed
I don't think they were ever mandatory in the US, but many cars have them anyway, usually imports(the ones actually imported via container ship) since they cater to multiple markets.
Anyway, here's the full EVTM section.
Thank you very much Matt, highly appreciated! I'll give these to my electrician, let's see if he can come up with something.
Al
DRL's are never manual. They were mandatory for all cars in Canada from 89 or 90 on but I don't know until when. They also allowed indicators glowing brightly in amber I think, don't remember exactly... in the US they were always allowed but not mandatory as far as I know. In Europe they've been mandatory in a lot of countries since a couple of years (or if your car is too old to be equipped with them you have to switch on your standard headlights all the time) but they all have LED's and sometimes so low near the road that they don't do their job like they should... That's why I like the Canadian version; it's where usually the lights are and it beams high with reduced output so it isn't too bright but is still seen from a great distance.
1 - 12 of 12 Posts
