what do i need besides the springs? please and thank you for the answers
An alignment and to go slow over speed bumps also shorter rear sway bar end links are recommended.
Here what im getting
2inch drop all around
shortened rear sway bar
shortened end links
new coil cups
new tie rods
new tires
outer connecting rods
and an alignment :)
where do u get the shorter rear sway bar end links? if u dont mind me buttin in?
1994 Cougar XR7 DOHC/5-Speed
shortened end links
new coil cups
new tie rods
new tires
and an alignment :)
You only need shorter endlinks, not a sway bar.
And spring cups, tie rod ends and tires you only need to replace if they are worn out. The ones you have now won't effect anything when you lower the car(unless of course they are worn out).
Outer connecting rods??? whaaa???
Energy suspension makes endlink kits in various sizes, I've found them at autozone before.
yea my car needs tie rods, tires, and new rear coils so ive out all this off long enough lol.
Also the person im getting my shortened links from are sending me them with the springs i dont need to shop around
