1 - 2 of 2 Posts
Is the task of drum to disc pretty easy, I'm sure it's changing a few suspension parts but thats not a big deal to me.........but those drums brakes aren't doin the job they are suppose to do, i think thats why in 96 why went with disc........Casue right now I'm goin through rotors left and right cause all the brake power is given to the front brakes. I've adjusted the rear brakes already, it worked good for maybe a week or so then went back to normal again..........So will rear disc make a big difference?......is there different porportion valves by the brake booster?? Does ABS have to be installed in order for the rear disc to work correctly or can it work without ABS........I mean it sounds simple, just replace the suspension parts in the rear, hook up the brake lines to the calipers, and bleed the system.......But please let me know if there is any issues with changing it over to disc...........Thanks
1 - 2 of 2 Posts
