I got a check engine light on and I got the code and I got a p0340 so I change the camshaft position sensor reset it and drove fine until I stop and try it again and the freakin code came back again anything I miss ? help please :confused:
When i had mine replaced, they replaced the synchronizer as well. I was told that it was messed up also. If they would have replaced it the problem would have come back due to the fact that the synchronizer would chew up the new one again. When i got the parts back i noticed that the synchronizer was messed up as well. It looks like a small distributor.
yes, I had this exact same problem with mine chewing up cam position sensors. I finally took out the synchronizer, and found out there was a lot of play in it (going side to side, was oval shaped) bought a new one from Ford, replaced it and havent had a problem since.
